Fog Light ???
Old May 16, 2007 | 07:27 PM
I Drive Naked's Avatar
Default Fog Light ???
Installing Fog Lights on an RS, is it a plug n' play, meaning the plugs are already there for the lights in the bumper?
I don't want to crawl under there being in my present state of recovery/
I ask this b/c I removed the trim panel to the left of my wheel yesterday, the one that houses Power Mirrors Cruise Control and the Fog Light Switch.
There were 2 connectors behind it, but I am unsure as to which function out of the 3, those 2 control.
Better yet, let me affix a pic.
Someone explain.
I want fog lights.
Old May 16, 2007 | 08:33 PM
silvercoupe97's Avatar
Default RE: Fog Light ???
Yes sir, most Mitsu cars come prewired as you can see and noticed according to your pic. Now all you have to do is find the foglight connectors zipped tied and covered by some plastic on the radiator bracket and close to the foglight openings.
Oh yeah, if you get the control panel that goes there, it's a matter of plug and play.
I've proven this plug and play thing time and time again, where the car is already prewired, you just need the components and to fill in the fuse slot.
Not directed at you Josh. That was a general statement.
Old May 16, 2007 | 09:05 PM
I was hoping you'd reply to this one.
Question #2:
What do I need to buy?
Foglights (obviously)
Switch.
Fuse (amp?)??
Brackets?
Or do I just rig-a-jig the existing piece
Old May 16, 2007 | 10:07 PM
That piece inside the opening should be just a plate that you can remove, unless the whole housing is a blank plate, then you will have to remove the whole black housing and replace it with an open fog light housing.
Yes, to the fog light bracket, fog lights, control panel to replace your existing one (because the slot is already cutout for the switch),
dasher714
Oct 21, 2019 10:51 AM
lilstally
Jun 1, 2006 12:12 AM
UBDreamin
Sep 15, 2005 09:34 PM
Eclipse4ever01
Jan 8, 2005 11:55 PM
terylsdad
Nov 29, 2004 01:36 PM
