front wheel to all wheel drive
I want to change my front wheel drive GSX to a all wheel drive, does anyone know if that would be expensive? and for the price, is it really worth it?
RE: front wheel to all wheel drive
**NEWS FLASH** If you have a GSX you already have AWD!!!!But if your talking about swapping a GST to AWD. Yes its been done, no its no the easiest. Suspension, gas tank and all that is different. You need drive shaft, x-case and a lot more. Not really worth it IMO, just buy a GSX. Easier and faste
yeah my bad GST, alright thanks. another thing, i want to take my mufflerand everythingoff and get a full exhaust, since i have a welder i can make one myself but i dont know if straight pipes will work.
Just buy a good aftermarket exhaust like apexi or greddy. They will bolt right up.
First off how much money do u have, b/c its very expensive and time consuming.
it can be expensive, but it's one of the cheaper performance parts you can buy for your car
i just need to buy some pipe and then im good, i'll weld that right on with 1 resonator and the stock muffler, that should be good
ORIGINAL: se4448 i just need to buy some pipe and then im good, i'll weld that right on with 1 resonator and the stock muffler, that should be good |
Well unless you have a pipe bender that can do mandrel bends then its pointless to do your own exhuast, youll just be hurting the system
can't you buy pipes already bent and just weld them together to make the exhaust, no matter how tight the bends are?
