front wheel to all wheel drive
Old Oct 28, 2007 | 12:28 AM
se4448's Avatar
Default front wheel to all wheel drive
I want to change my front wheel drive GSX to a all wheel drive, does anyone know if that would be expensive? and for the price, is it really worth it?
Old Oct 28, 2007 | 12:35 AM
Natedogg89's Avatar
Default RE: front wheel to all wheel drive
**NEWS FLASH** If you have a GSX you already have AWD!!!!But if your talking about swapping a GST to AWD. Yes its been done, no its no the easiest. Suspension, gas tank and all that is different. You need drive shaft, x-case and a lot more. Not really worth it IMO, just buy a GSX. Easier and faste
Old Oct 28, 2007 | 12:40 AM
se4448's Avatar
yeah my bad GST, alright thanks. another thing, i want to take my mufflerand everythingoff and get a full exhaust, since i have a welder i can make one myself but i dont know if straight pipes will work.
Old Oct 28, 2007 | 08:49 AM
bestwiseguy's Avatar
Just buy a good aftermarket exhaust like apexi or greddy. They will bolt right up.
Old Oct 28, 2007 | 10:37 AM
dsm1990gsx's Avatar
First off how much money do u have, b/c its very expensive and time consuming.
Old Oct 28, 2007 | 11:36 AM
sk8dudety's Avatar
it can be expensive, but it's one of the cheaper performance parts you can buy for your car
Old Oct 28, 2007 | 01:08 PM
se4448's Avatar
i just need to buy some pipe and then im good, i'll weld that right on with 1 resonator and the stock muffler, that should be good
Old Oct 28, 2007 | 04:47 PM
Natedogg89's Avatar
ORIGINAL: se4448
Its not always that easy. Why do you want to keep the stock muffler? Even if you run 3 inch turbo back, which isnt good on a T-25 anyway(no backpressure) you still get to the muffler and then its reduced again. Just buy a universal Apexi, hks, or greddy muffler and weld that up if you insist on making your own. I would say just buy a already bent system from greddy or apexi and be done with it. Have you looked under the car? It takes two nasty bends which i couldnt even get a exhaust shop to do for me when i wanted 3inch with my old HKS muffler. Needless to say i sold that muffler and bought a Apexi system.
Old Oct 29, 2007 | 06:40 AM
Well unless you have a pipe bender that can do mandrel bends then its pointless to do your own exhuast, youll just be hurting the system
Old Oct 29, 2007 | 08:57 AM
se4448's Avatar
can't you buy pipes already bent and just weld them together to make the exhaust, no matter how tight the bends are?
