Fuel Filter
Old Jan 22, 2005 | 06:00 PM
Mao007's Avatar
Default Fuel Filter
I finally found the fuel filter on my 1998 Eclipse Spyder and now looking for hints on how to remove it ? how do you possibly remove the bottom fitting? Also, how often should this be replaced ?
Old Jan 22, 2005 | 06:48 PM
get435's Avatar
Default RE: Fuel Filter
I was told they have 2 filters? is this correct?
Old Jan 22, 2005 | 08:25 PM
vertstanggt's Avatar
I havn't done that yet, it's been too cold, but where are they at?
Old Jan 23, 2005 | 05:32 AM
DSMTalonAWD51's Avatar
its not tricky to remove just HARD to get that bolt off. I dont know if the last guy who changed it was just trying to be an ***, but I had to call up my friend hercules to come over an losen the bolt for me. just buy the filter first and look at where the bolts are its simple. and remember to cut thefuel fuse, crank the engine until its dead, and dont smoke
Old Jan 23, 2005 | 09:47 AM
get435's Avatar
I was told there is a filter in the tank as well?
Old Jan 23, 2005 | 04:00 PM
is it turbo or na? im not sure about na but for turbo its just an in line fuel filter under the hood next to the battery
Old Jan 23, 2005 | 05:09 PM
You don't have to drain the fuel, I've just always put a couple of vice grips on each side of the line to cut it off then you can replace the filter.
Old Jan 23, 2005 | 09:33 PM
customizedrides's Avatar
Take my advice from experience and wear safety glasses. I took a shot in the eye and burned like a mo' fo' But yes there are two filters. The one under the hood should be done with every tune up. The other one is a sock attached to the pump inside the tank. This one only needs to be replaced when you do the fuel pump. Or if you've had the car for years and the pump is a beast running strong you may want to pull it out and pop a nw sock on to be safe. I would pull the fuse and crank the engine so you don't have any burps, because my lines were pinched to and that didn't help any.
Old Jan 25, 2005 | 05:18 PM
huh, I've done lots of filters over the years and never had any problems. But glasses are def a good idea.
Old Jan 25, 2005 | 09:46 PM
Yeah that was the first time out of I don't know how many that I had it happen and that's just because the shop teacher told me it would happen and I said I'd never had a problem. Damn teachers...think they're soo smart. But for anyone concerned my eyes are doing well now. I only looked stoned for about a week
