fuel pump
Old Apr 20, 2004 | 08:02 AM
turbodsmdavid's Avatar
Default fuel pump
im about to buy a fuel pump.. now i need to know if any 2g eclipse fuel pump will fit or i need a 2g GST fuel pump?
Old Apr 20, 2004 | 01:13 PM
SpyderGS's Avatar
Default fuel pump
you'll need a 2g fuel pump, however, you can spend a little extra and get a SupraTT fuel pump. It basically fits the same, and flows more. Plus toyota reliability. Conicelli mitsu sells them for cheap for clubDSM members. Very good choice if you plan on upgrading. Don't bother getting the stock unit again. The 3KGT fuel pump also works, but the supra tt is a little better.</P>
Old Apr 23, 2004 | 02:48 AM
total_eclipse's Avatar
Default fuel pump
man just buy a 255LPH pump from elderbrock..or suh'n like that..its cheap..thats what i got...
Old Apr 23, 2004 | 12:16 PM
SpyderGS's Avatar
Default fuel pump
The fuel system is something you don't want cheap on. Case in point, a few years back, my buddy bought some no-name 190lph fuel pump for his 1g daily. Mostly everything on his car was stock except for the basics, and he just turned up the boost a little. He said one day the egt's went way high and he was getting knock all around. He pulled over, and checked just about everything to see if something was leaking or cracked, but everything checked out fine. He started it up, then drove like 4 minutes and it started happening again. He ended up having to get it towed to his house. The last thing he ever thought about was to check the fuel pump since it was a new aftermarket unit. The pump wasn't broken, but it was malfunctioning somehow....i can't remember exactly how. But the point is just buy something reliable, and you'll be worry free in the end.
Old Apr 24, 2004 | 01:47 PM
Default fuel pump
should i be worry free with a walboro 255 fuel pump?</P>
Old Apr 26, 2004 | 12:57 AM
SpyderGS's Avatar
Default fuel pump
Yeah, walboro is a pretty reliable company. It's the no-name brands you gotta look out for
Old Apr 26, 2004 | 02:32 PM
BurntGSX's Avatar
Default fuel pump
would it be better to buy new, or just hack the stock FP? Im not being a cheap ***, just have better things to spend $150 on right now
Old Apr 28, 2004 | 05:00 PM
91eclipse's Avatar
Default fuel pump
u need a 2g fuel pump
Old Apr 30, 2004 | 06:11 PM
BurntGSX's Avatar
Default fuel pump
yeah...Im confused at that statement 91... I drive a 97, being a 2nd gen. or are you talking something other that that with 2g? anyways, how much does it take to hack one? more work that worth?
Old May 1, 2004 | 03:58 AM
SpyderGS's Avatar
Default fuel pump
Prolly more than it worth Burnt, getting a Walboro 190 or 255 is going to be better in the long run.
