Gauges
Old May 10, 2010 | 12:45 PM
vangsee08's Avatar
Default Gauges
All of my gauges are not working. Does anyone know how to fix this.
Old May 10, 2010 | 04:48 PM
just the lights? or the actual guages. It sounds like a fuse to me
Old May 10, 2010 | 06:06 PM
vangsee08's Avatar
the actual gauges. First the lights werent working but now i fixed it by checking the fuses and switching them. Now none of the gauges work. Where can i check if its properly connection.
Old May 10, 2010 | 06:10 PM
you have to remove the dash panel in order to find the wiring
Old May 10, 2010 | 06:18 PM
vangsee08's Avatar
so where do i start. how do you do that.
Old May 10, 2010 | 08:08 PM
vangsee08's Avatar
i was able to take out the gauges now. I put them back on but see no difference. It still doesn't work. where would i find the other end of the wires from the gauges. is it under the hood????
Old May 10, 2010 | 09:12 PM
for all of them not to work i can only see it being that connection or another fuse. The wires go to the ecu or individual sensors
Old May 10, 2010 | 10:39 PM
3000gt16's Avatar
There is a fuse for the gauges I belive in the fusebox under the hood.
Old May 11, 2010 | 03:19 PM
vangsee08's Avatar
i would try that but the point is that i dont have the fuse box cover telling me which fuse is for what. Does anyone have a picture of the fuse box cover?
Old May 11, 2010 | 03:21 PM
vangsee08's Avatar
i read somewhere that after you take out the battery and battery tray there should be a connection there too. Is that right because i tried that but didn't find anything. So i should check the ecu??
kiwicom
Aug 13, 2004 03:12 AM
Boxy458
Jul 2, 2004 04:04 PM
briansrt
May 25, 2004 03:43 AM
fdgirl
Apr 17, 2004 03:57 AM
fdgirl
Apr 5, 2004 08:53 PM
