Gear head question
Old Dec 15, 2005 | 11:12 PM
wsuweston's Avatar
Default Gear head question
So here is the question that I can not find an answer to. I have a 95 GS eclipse. Everything was cool with the car and then my code came up for rear o2 sensor, shop replaced it and then it went on again they checked it and it was fine. Now the code trips every like 5k miles or so. It has done this like 5 times in the past 2 years. So there's the question to all you gear heads that know way more than me. I have checked with several dealerships and they can't answer the damn problem.
Thanks for ur help
Old Dec 16, 2005 | 01:53 AM
domestickilla's Avatar
Default RE: Gear head question
list your mods if any n that might help figure this out
Old Dec 16, 2005 | 03:06 PM
wsuweston's Avatar
When it all started I had wires, cold air, and muffler, But have since taken of cold air nd it has happened once more.
Old Dec 16, 2005 | 03:34 PM
eclipsed4u's Avatar
maybe they replaced the wrong o2 sensor?
what is the exact code?
Old Dec 16, 2005 | 05:52 PM
wsuweston's Avatar
Code 21
Is that the rear o2 sensor?
Old Dec 16, 2005 | 06:55 PM
eclipsed4u's Avatar
its for the o2 sensor...but it doesn't specify which one.
Old Dec 16, 2005 | 07:09 PM
wsuweston's Avatar
The second time the code came up I had the front one replaced.
Old Dec 16, 2005 | 09:18 PM
Sanguinius's Avatar
Try replacing the other one see what happens there.
Old Dec 16, 2005 | 09:23 PM
wsuweston's Avatar
Both front and rear o2 sensors were replaced, the code only shows up every 5,000 miles or so.
Old Dec 16, 2005 | 11:29 PM
ORIGINAL: wsuweston
Will fuel issues cause the same thing since o2s are looking at temps and AFRs maybe lake of fuel or clean burn???? just spit balling I guess but something to think about I suppose
