glove box lock
Old 11-24-2007, 01:21 PM
itsme71190's Avatar
Default glove box lock
umm yea. sister locked it. and i cant get it unlocked....
Old 11-24-2007, 01:45 PM
Default RE: glove box lock
You cant use your key?
Old 11-24-2007, 02:39 PM
yeah your key should open it..
Old 11-24-2007, 02:41 PM
Sometimes they are a little hard... but if you juggle the key around in the lock while trying to turn it, it should open up
Old 11-24-2007, 04:22 PM
shreff99's Avatar
Also try spraying some PB Blaster or WD40 into the lock and work it with the key and if you get it open, spray some lithium grease in there to keep it lubed.
Old 11-24-2007, 10:59 PM
itsme71190's Avatar
ok. ill try in the morning
Old 11-24-2007, 11:48 PM
Natedogg89's Avatar
The only way to lock it is with the key...and thats what you also use to open it
Old 11-25-2007, 02:31 PM
did you ever get it open?
Old 11-25-2007, 05:53 PM
You need to make sure it is the main key, and not the "backup" (A.K.A vallet key). The vallet key will only open the driver side door and start the car. It won't open the glove box, the hatch, or the passenger side door.
Old 11-26-2007, 08:37 PM
shreff99's Avatar
Good point Gregory...I forgot about that "valet" key[sm=smiley20.gif]
Quick Reply: glove box lock
