glove box lock
Old Nov 24, 2007 | 01:21 PM
itsme71190's Avatar
Default glove box lock
umm yea. sister locked it. and i cant get it unlocked....
Old Nov 24, 2007 | 01:45 PM
Default RE: glove box lock
You cant use your key?
Old Nov 24, 2007 | 02:39 PM
solina08's Avatar
yeah your key should open it..
Old Nov 24, 2007 | 02:41 PM
Sometimes they are a little hard... but if you juggle the key around in the lock while trying to turn it, it should open up
Old Nov 24, 2007 | 04:22 PM
shreff99's Avatar
Also try spraying some PB Blaster or WD40 into the lock and work it with the key and if you get it open, spray some lithium grease in there to keep it lubed.
Old Nov 24, 2007 | 10:59 PM
itsme71190's Avatar
ok. ill try in the morning
Old Nov 24, 2007 | 11:48 PM
Natedogg89's Avatar
The only way to lock it is with the key...and thats what you also use to open it
Old Nov 25, 2007 | 02:31 PM
solina08's Avatar
did you ever get it open?
Old Nov 25, 2007 | 05:53 PM
Gregory's Avatar
You need to make sure it is the main key, and not the "backup" (A.K.A vallet key). The vallet key will only open the driver side door and start the car. It won't open the glove box, the hatch, or the passenger side door.
Old Nov 26, 2007 | 08:37 PM
shreff99's Avatar
Good point Gregory...I forgot about that "valet" key[sm=smiley20.gif]
