going back to conventional oil or not?
Old May 15, 2006 | 07:50 PM
alfmetal's Avatar
Default RE: going back to conventional oil or not?
so EMonz57 says dont switch back to conventional ?
anybody dissagree ?
thanks for all the help.
Old May 15, 2006 | 10:32 PM
Sanguinius's Avatar
DO NOT switch back. Once you go full synth you will do MORE damage if you switch back.
And Corvette's actually REQUIRE Mobile 1 no less or you will void the warranty. For those of you that DON'T know oils Mobile 1 is the fully synthetic oil made by Mobile.
Old May 16, 2006 | 12:53 AM
alfmetal's Avatar
hey thanks again sanguinius.
im staying with synth
one last question.
it will be ok to use synthetic blend motor oils? after i used the full synth on my car?
Old May 16, 2006 | 06:02 AM
TX97GST's Avatar
On the switching back to conventional I have herd definatly not to because fully syn motor oils have detergents in them to break down conventional oils.
Old May 20, 2006 | 02:49 AM
alfmetal's Avatar
thanks for your answer tx97gst , so i guess if you drain the fully synthetic oil and add conventional, what is left ( the residuals ) of the fully synthetics will break down the conventional oil and actually dont have anything to do with the viscosity
Mrrenzo
Mar 16, 2009 03:22 PM
hogbygardd
11
Nov 21, 2008 06:31 PM
Silvertooth
Mar 16, 2007 04:42 PM
jdmeclipse92
Oct 29, 2004 12:58 AM
