Granny shifting
ORIGINAL: FireDoc
If you were wondering, granny shifting is what truckers do to shift without the use of the clutch on older transmissions. You run the rpms up from one gear, let off and pull the shifter out of gear and push it into the next before the rpms drop too much and you just end up grinding. It is a normal practice with our forestry water tankers at the firestation. They're ancient.
Also the reason for double clutching isn't to prevent gringsing as much as to match RPMS easier in the trucks because they didn't have syncho's to match things up. And it kept the truckers from snapping the locking pin on the clutch off due to the massive amounts of torque that the diesel engines put out.
![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
Your trans basically has 4 gears (overdrive being the largest). Keeping it off basically prevents the transmission from applying that gear. I will not increase your 0-60 times by locking it out (OD off), but it can prove to make your car more responsive at cruising (roughly between 35-50MPH) speeds by locking it out simply by keeping your engine within it's powerband. The term "overdrive" is used to describe that the ratio of that gear is being overdriven as opposed to gear reduction. YOu should apply the OD at highway speeds to prevent overrevving of the engine and for better fuel economy.
Joel, CA
Joel, CA
Also, I never said it was to prevent grinding, simply that grinding will occur when not done properly. Maybe you should spend a little less time putting in your insignificant opinion and your arbitrary instructions trying to get yourself another pretty little star and actually READ the subject you are posting on.
ORIGINAL: Sanguinius
OOOOHHH *Nasty buzzer sound* WRONG the correct answer is "What it DOUBLE CLUTCHING" Sorry thanks for playing LOL (No hard feelings lol but granny shifting is basically taking your damn sweet time shifting gears.)
ORIGINAL: FireDoc
ORIGINAL: FireDoc
Why is it called double clutching when the clutch has nothing to do with it? By the way mister buzzer, check your dictionary, SANGUINEOUS.
