Grinding Noise?
wondering if anyone else has had this problem
got a 96 eclipse non turbo 2.0
and when i make a slow hard right turn i hear this grinding noise and i cant figure out what it is.
It usually happens when i apply the brakes and ive checked the pads n **** and they are good.
Open for info
Open for info
If you are sure it isn't the brakes, you should try repacking or replacing your wheel bearings. Frontwheel drive cars are rough of everything up there because they take all the stresses from braking, cornering, accelerating, etc.
ORIGINAL: FireDoc
Thats what I meant...Wheel bearings ...not the Ball joint
Like I said check the CVs the ball joints, the rod ends while you have it in the air for the bearings. Might as well make certain just in case something else is there that needs help better to know about it now than find out when it fails right?
The faster you get it checked the better. ive seen too many cars with broke ball joints tie rod ends sitting on the side of the road with three tires pointing one way and one going somewhere else. Bad sight indeed.
