Grinding Noise?
Old Oct 7, 2005 | 04:37 PM
Timmay's Avatar
Default Grinding Noise?
wondering if anyone else has had this problem
got a 96 eclipse non turbo 2.0
and when i make a slow hard right turn i hear this grinding noise and i cant figure out what it is.
It usually happens when i apply the brakes and ive checked the pads n **** and they are good.
Open for info
Old Oct 7, 2005 | 05:38 PM
Default RE: Grinding Noise?
Sounds like the ball joint or something to that effect. My friens 95TSi did that and he waited on it and ended up haveing to replace the axel and controll arm
Old Oct 7, 2005 | 05:59 PM
FireDoc's Avatar
If you are sure it isn't the brakes, you should try repacking or replacing your wheel bearings. Frontwheel drive cars are rough of everything up there because they take all the stresses from braking, cornering, accelerating, etc.
Old Oct 7, 2005 | 06:21 PM
Sanguinius's Avatar
Check your CV joints as well. Is it only when you turn one direction?
Old Oct 7, 2005 | 06:48 PM
TheAdvocate's Avatar
Check to make sure nothing is rubbing your tire/rim... Make sure there isnt anything in there that could hit it...
Old Oct 7, 2005 | 07:56 PM
ORIGINAL: FireDoc
Thats what I meant...Wheel bearings ...not the Ball joint
Old Oct 10, 2005 | 12:54 AM
Timmay's Avatar
IM leaning more to the wheel bearings and im gonna get them changed some time this week
Hope that solves the problem
Old Oct 10, 2005 | 01:33 AM
Sanguinius's Avatar
Like I said check the CVs the ball joints, the rod ends while you have it in the air for the bearings. Might as well make certain just in case something else is there that needs help better to know about it now than find out when it fails right?
Old Oct 10, 2005 | 06:41 PM
Lil red's Avatar
The faster you get it checked the better. ive seen too many cars with broke ball joints tie rod ends sitting on the side of the road with three tires pointing one way and one going somewhere else. Bad sight indeed.
Old Oct 10, 2005 | 09:15 PM
Sanguinius's Avatar
I've even seen a car with 3 wheels one way the fourth lying flat under the car with the transaxle still connected to it.
