GST engine swap to GSX
Old Jan 28, 2009 | 03:32 PM
97gsdragon's Avatar
Default GST engine swap to GSX
Picked up a 95 GST. $700.00 and only 117xxx miles. All stock! What a steal!
It needs alittle work but that is expected. Its an automatic and I want a manuel.
I was wondering if I could swap my engine into a GSX. I was going to just swap the tranny but didn't want to change everything. And I'm not too found of the interior. Needs a bunch of work. Swapping into a shell seems easier to me, and gives me an opportunity to rebuild just for fun. But if that don't fit then I'll just find a GST and do that swap instead.
Also who do you guys suggest I buy the rebuild kit from? I just don't want to waste my money on crappy stuff.
Old Jan 28, 2009 | 07:17 PM
dsm1990gsx's Avatar
Default RE: GST engine swap to GSX
The 2g gst and gsx's have the same engine.
Old Jan 28, 2009 | 09:24 PM
97gsdragon's Avatar
I know that. I was wondering if mitubishi did anything different between the GST and the GSX to make it impossible.
Old Jan 28, 2009 | 10:30 PM
TheAdvocate's Avatar
The flywheel is acutally bigger in the GST... The tranny wont bolt up on the GSX with the GST flywheel still on.
Old Jan 29, 2009 | 02:41 PM
the engine itself is the same, so yes you can swap, but you of course need a GSX tranny, t-case, flywheel, ect. But the block and head itself is the same. Also the exhaust would have to be from a gsx
Old Jan 31, 2009 | 02:33 PM
97gsdragon's Avatar
alrgiht cool thanks guys.
and what about the rebuild kits. has anyone ever used them before. i would like to go forged but thats kind of out of my price range.
Old Feb 1, 2009 | 10:36 AM
Ive gone with eagle rods, and ross pistons... Seems to be ok. But unless your gonna really use it, I would just go with 1g rods and 2g pistons.. You can handle 400 hp and spend less than half the price doing it.. So unless you plan on going all out, I personally dont think its worth it.
Old Feb 1, 2009 | 11:43 AM
dsm1990gsx's Avatar
^^^ I agree w/ that, make sure you get the block looked at first before you order pistons.
victim619
Mar 8, 2021 12:02 PM
jjgsx
Aug 19, 2006 05:14 AM
D3SOLATION
Feb 15, 2005 02:22 AM
magno_313
Jan 8, 2005 11:57 PM
mike96eclipseRS
Dec 19, 2004 05:07 AM
