GST questions
Old Jun 10, 2008 | 11:50 PM
ridingDSM0201's Avatar
Default GST questions
ok well i have been told that 95-96 crankwalk more offten tehn 97-99... why is that? just cause the age or is there something different to there bearing setup, or what not? If so what would i do to the engine when rebuilding it so its not as easy, or would i have to buy a 97-99 block?
Old Jun 11, 2008 | 01:46 AM
silvercoupe97's Avatar
Default RE: GST questions
ORIGINAL: ridingDSM0201
1) Don't allow yourself to overestimate crankwalk. Those motors are usually beaten on, but there are some 2Ga cars with the original motor. One more thing, even those year cars...not all of them walk. Yes, 95-96 are thee crankwalk prone 2G motors because the 2GBs had something done to help alleviate the walk, but can still happen...hell, it can happen to any manual tranny motor out there. Those quickest to yell out crankwalk are the ones who have jumped on the crankwalk train because they don't know what it is and/or what could possibly cause it.
2) Don't worry about crankwalk, jut replace the bottom with a 1G bottom and be done with it or replace the entire 2G motor with a 1G motor. Why? Because they have a stronger crank system.
3) Run the 2GA motor until or if the motor walks, then get a 1G bottom or 1g motor.
Old Jun 11, 2008 | 10:46 AM
I wrote a whole thing on this and the damn post problem happend again.
Either way, to reitterate what Silvercoupe said, don't over estimate it, even Supras can crankwalk.
Old Jun 11, 2008 | 07:02 PM
darknigh7th's Avatar
yeah i wrote in on it too and it screwed up on me as well lol.
Old Jun 11, 2008 | 08:40 PM
I forgot about the issue of posting and got lucky somehow! I would have been pissed too...again, lol.
Old Jun 11, 2008 | 09:04 PM
yes supras car but not that often, the 2G is alot ALOT more common to have bottom end issues than even a 6 spd supra (which also can crankwalk given the wrong crankpulley clutch flywheel combos)
Old Jun 12, 2008 | 06:13 PM
tjbiker031's Avatar
its nothing to get your self worked up over and start pulling your engine and swapping motors just yet, just have a plan ready if it ever does
Old Jun 12, 2008 | 08:43 PM
i bought a 6-bolt to build up, but hopefully my 7 won't walk. The only reason i bought a 6 bolt was so that when i spend a bunch of money on an engine, hopefully it won't die cause of something stupid.
Old Jun 13, 2008 | 12:28 AM
sk8dudety's Avatar
yea man thats something i was gonna suggest, you can buy a 1g block or motor and build it up. then that way if you're motor does blow you'll have a built one ready to pop back in. but crankwalk isnt as normal as people say it is really.
Old Jun 13, 2008 | 04:30 AM
yeah i'm not worried about it, but hey the block was 75 so i figured might as well do it right. just play it safe
