GST Spyder - Back passenger window?
Well my window in my gst spyder...on the passenger side in the back
since i got it it has not rolled down....and cant figure how to get to it
when u try to roll it down it just wants to go down it is like jamed
the window motor is good
anyone who can help..."HELP"
Thanx
50ul
Thanx
50ul
ya ryan its not that easy....there is no way to get into it....after i took every plastic pieace off....the are only two lil openings to small todo anything?
dont know?
dont know?
well those two little holes are probably so you can stick a socket in there and loosen the bolts on the window track that connects to the window, see if you can loosen those and jiggle the window around till you get it on the track... also is there weatherstripping around the window that you could pull off to see better down the panel?
You probably could do it Nate... but remember, if anything goes wrong and that window busts.... I have no doubt thats the most expensive piece of glass on that entire car, lol. Plus, windows (specificaly power windows) are very very touchy anything goes wrong and itll just get worse. MUCH worse, (I learned on my 3G)
