GST Spyder - Back passenger window?
Old Dec 21, 2007 | 02:23 AM
50ul }{4ck3r's Avatar
Default GST Spyder - Back passenger window?
Well my window in my gst spyder...on the passenger side in the back
since i got it it has not rolled down....and cant figure how to get to it
when u try to roll it down it just wants to go down it is like jamed
the window motor is good
anyone who can help..."HELP"
Thanx
50ul
Old Dec 21, 2007 | 02:27 AM
Dusty Eclipse's Avatar
Default RE: GST Spyder - Back passenger window?
Its off the track, Nate.
Old Dec 21, 2007 | 02:37 AM
how the H3ll do i get to it
ive tried everything
Old Dec 21, 2007 | 02:45 AM
It seems like it should just be a matter of taking out the rear plastics...
Old Dec 21, 2007 | 08:35 AM
ya ryan its not that easy....there is no way to get into it....after i took every plastic pieace off....the are only two lil openings to small todo anything?
dont know?
Old Dec 21, 2007 | 09:07 AM
sk8dudety's Avatar
well those two little holes are probably so you can stick a socket in there and loosen the bolts on the window track that connects to the window, see if you can loosen those and jiggle the window around till you get it on the track... also is there weatherstripping around the window that you could pull off to see better down the panel?
Old Jan 27, 2008 | 12:55 PM
i tried but i cant see anything in there
Old Jan 27, 2008 | 01:00 PM
RCJr9186's Avatar
flashlight would probably be a good tool in that situation.
call a windo guy, they will put it back on track for like 20 or 30 bucks.
Old Jan 27, 2008 | 01:07 PM
ron well calling someone to come and work on my car is a no...i dont let anyone touch my baby
Old Jan 27, 2008 | 02:03 PM
You probably could do it Nate... but remember, if anything goes wrong and that window busts.... I have no doubt thats the most expensive piece of glass on that entire car, lol. Plus, windows (specificaly power windows) are very very touchy anything goes wrong and itll just get worse. MUCH worse, (I learned on my 3G)
