gsx??????????
Old Jun 16, 2006 | 05:54 PM
redrum1er's Avatar
Default gsx??????????
any one know whats the stock boost on a 95 gsx. also cant get it to boost over 9 psi with the 16g in it now is that normal
Old Jun 16, 2006 | 06:10 PM
5Tizzle's Avatar
Default RE: gsx??????????
stock- 8-10 psi
Old Jun 17, 2006 | 02:27 AM
with the restrictor out the stock will be around 10-12psi. But no it is not normal for it to only boost 9psi. You must have a leak somewhere.
Old Jun 19, 2006 | 06:06 PM
redrum1er's Avatar
what are the things i should look at for a boost leak and how do i check
Old Jun 19, 2006 | 08:23 PM
agallardo's Avatar
Do you have a manual boost controller?
Old Jun 20, 2006 | 02:42 PM
redrum1er's Avatar
no. no manuel boost controler. only k&n intake 3" upper i.c pipe and custom 3" exhuast whith a flow master and msd wires with denso iriadums
Old Jun 20, 2006 | 06:02 PM
Brandon's Avatar
Check BOV?
Old Jun 20, 2006 | 06:11 PM
Just putting in a turbo doesnt automatically mean it is gonna boost higher [sm=headbang.gif] You need a MBC in order to turn the boost up higher than stock
Old Jun 21, 2006 | 06:13 PM
redrum1er's Avatar
did check bov its off a first gen and shouldnt it at least boost up to stock cause before the trubo it was at 13psi now it dont wanna go past 9psi
Old Jun 22, 2006 | 11:55 AM
check all intake hoses and intercooler pipes.
