GSX Problem
Old Jan 10, 2004 | 10:09 PM
White-lighting's Avatar
Default GSX Problem
<img border="0" src=smileys/smiley11.gif border="0"> I have engine starting problem on my 97' gsx. i replace the fuel pump and the fuel relay on the car and the car still will not start.
The engine will rotate, but the engine will not fire up to start. Every thing works inside the vehicle and when ingnition is on the fuel pump does not turn. Plus, when wired to the battery the pump comes on. Its recieve fuel , but the car will not turn over. NEED HELP!
Old Jan 12, 2004 | 08:53 PM
Mitsu-Tech's Avatar
Default GSX Problem
you getting anyspark to the plugs i can almost bet there not firing post your findings and we'll see if you can get that little beast to fire up</P>
you might be barking up the wrong tree with the fuel pump you have a few things to look at if theres no spark and no fuel ...can you read any codes on the computer,,, if not does the check engine light for at least 5 seconds when the key is turned to the on position, are you getting power to the distributor/coilpacks and how much (volts) and whats coming out .</P>
we'll start there and see where it takes you</P>
Old Jan 16, 2004 | 08:25 PM
Default GSX Problem
When the Ignition is on the fuel Pump does not come on! The check engine light does not come on either and there is still not any spark comming through. Tested the spark and there is nothing.
Old Jan 16, 2004 | 09:20 PM
Mitsu-Tech's Avatar
Default GSX Problem
if the ecm does not light the check engine light at any time</P>
(ANY TIME AT ALL )check to see if you have any power to it......</P>
Old Jan 16, 2004 | 09:24 PM
Mitsu-Tech's Avatar
Default GSX Problem
if there is no power the the ecm ...</P>
just check the fuse if the fuse is good you can possably have a break in the wire to the computer (doubt it )</P>
there is also a relay that controls both fuel and spark located in the upper right hand side on the engine compartment...</P>
before you worry about any relays lets see if that computer is working first</P>
Old Jan 22, 2004 | 09:09 PM
Default GSX Problem
The engine does not recieve a spark and checked colts on fuel pump,relay and everything else but only missing 6 volts. I Bought a new ecu and hopefully it works. I tool the orignal ecu out and it smelt burnt so hopefully it works.
Old Jan 22, 2004 | 10:05 PM
Mitsu-Tech's Avatar
Default GSX Problem
Well let me knowif the ecu works out for you </P>
</P>
Rick</P>
Old Jan 29, 2004 | 04:34 PM
Hybrid4g64's Avatar
Default GSX Problem
6v loss is a lot....cause ur are only reciving 12 though it....dont say only because 6 is almost cadastrofic(sp?)
Old Jan 30, 2004 | 11:47 AM
Mitsu-Tech's Avatar
Default GSX Problem
Cada who ? .......some sensors only receive 5 - 6 volts it's not a 12 volt world on sensors ...You just need to know what your looking for at,,, what Factory Specs are before you go and start pulling out parts ..</P>
</P>
going by what Wht Lghtng says it could be the ecm getting 12 or could be a fuelinjection relaywho knows where he is picking up the 5-6 volt readings from,</P>
pretty much it seems as he is a little shy of working on mitsu's and how an electronic fuel injection system works .......</P>
eclipse120
May 10, 2011 11:43 AM
rsanty2000
1st Generation
Dec 5, 2009 01:20 PM
sickend
Sep 12, 2006 06:25 AM
buttascotch_3
Jul 17, 2006 06:00 PM
DjCorkscrew
Mar 20, 2006 11:18 PM
