gt35r
Old Oct 27, 2006 | 05:09 PM
  #21
estraw's Avatar
Default RE: gt35r
what do you think it would spool at in the 2.4L 4g64??
Old Oct 27, 2006 | 05:17 PM
  #22
paintballproam's Avatar
Default RE: gt35r
1 psi 2867rpms 78% throttle
2 psi 2914 79%
3 psi 3000 84%
4 psi 3074 89%
5 psi 3168 97%
6 psi 3258 99%
7 psi 3352 100%
8 psi 3434 100%
9 psi 3512 100%
10 psi 3582 "
11 psi 3645 "
12 psi 3707 "
13 psi 3777 "
14 psi (full boost) 3875 rpm at 100% throttle "
That is one one guy put for results on his 2.0l lazer ( 1st gen AWD) with the fp 3052 at 14psi
Old Oct 27, 2006 | 05:31 PM
  #23
agallardo's Avatar
Default RE: gt35r
"yea and if you really want it to spool up quicker, make a stroker motor and you should cut the spool up time by a good amount"
How do you make a stroker motor? Or what exactly does that mean? (STUPID question) I just dont know what you mean and what exactly it is.
Old Oct 27, 2006 | 05:36 PM
  #24
Default RE: gt35r
Put a larger crank shaft basically, there is more involved but all it is, is putting a bigger crank shaft to cause a longer stroke aka more cubic inch displacement.
Old Oct 27, 2006 | 06:39 PM
  #25
Default RE: gt35r
ORIGINAL: paintballproam
2 psi 2914 79%
3 psi 3000 84%
4 psi 3074 89%
5 psi 3168 97%
6 psi 3258 99%
7 psi 3352 100%
8 psi 3434 100%
9 psi 3512 100%
10 psi 3582 "
11 psi 3645 "
12 psi 3707 "
13 psi 3777 "
yea and he didnt floor it from the start either. So that shows it can spool a bit quicker than that. Thats low boost for that low. I would think it would be set higher.
TheAdvocate
Mar 31, 2008 08:44 AM
posey27
Feb 29, 2008 09:53 PM
echostats
15
Jan 4, 2007 11:03 PM
93eclipsegsx
1st Generation
33
Nov 15, 2006 02:52 PM
