gutting my cat
Old Apr 16, 2005 | 08:02 PM
1998blackgst 240's Avatar
Default gutting my cat
Is there any way i can gut the cat on ym eclipse
Old Apr 16, 2005 | 08:23 PM
get435's Avatar
Default RE: gutting my cat
it would be alot easier to just buy a high flow cat.
Old Apr 16, 2005 | 08:50 PM
i have no cash though, i just spent it on my intake and BOV
Old Apr 16, 2005 | 09:05 PM
get435's Avatar
the only thing is if you do gut the cat it will effect the emissions/smog system and you would have to replace it before you got your emissions/inspection on the car.
Old Apr 18, 2005 | 07:09 PM
SpyderGS's Avatar
If you gut the cat, it'll most likely throw a CEL code from the second O2 sensor. But you can gut it, throw in a straight pipe inside the cat shell, and get a modded O2 sensor like the Supra guys do. As for the sound...well...people will most likely know you aren't running a real cat.
Old Apr 18, 2005 | 10:27 PM
DSMTalonAWD51's Avatar
all the o2 sensor after your cat does is check to see if the air is cleaner than before it came through the car, to fix the check engine light just take the o2 sensor out and tie it somewhere in the freshair. as for the cat gutting, why? leave it, dont go through the trouble for the 2hp you'll get, and it will sound and smell like crap. then when (not if, when) you get sick of the sound or you get caught for running no cat (huge fine) you'll have to buy a new one anyway.
Old Apr 18, 2005 | 10:57 PM
alright, yeah im just gonna leave it, buy a cat back exhaust system when i get the money, thanks alot
Old Apr 19, 2005 | 09:55 PM
SpyderGS's Avatar
The second O2 sensor will throw a "catalyst system efficiency" CEL if it's run for a certain period with no amounts of emissions gasses detected. The sensors have both a high and low limit for the amount of recognized emissions.
Old Apr 19, 2005 | 10:27 PM
Laxstar785's Avatar
i also must add gutting the cat probably isnt the healthiest thing to do.....unless cancer is your thing
motu1983
Sep 13, 2007 10:50 AM
motu1983
Aug 15, 2007 05:10 PM
jsaculles
Jun 13, 2004 10:33 PM
eclipse2gnt03
Aug 13, 2003 02:03 AM
eclipse2gnt03
Aug 13, 2003 01:58 AM
