Hard to start
Old Feb 1, 2007 | 03:44 AM
eclipsefanatic's Avatar
Default Hard to start
Hey guys, newbie here. Just got a 98 eclipse gst. Everytime i try to start up the car, it sounds like the car is having a hard time to start up. and when it start up it turn off and you have to restart a second timefor the car to stay on. not sure cause of cold weather. i had a civic brforeand it never have a hard time to start up. hope you guys can help me out why ismy car doing that. thanks alot
Old Feb 1, 2007 | 03:47 AM
jerusry's Avatar
Default RE: Hard to start
could be your idler screw needs to be adjusted, maybe plugs, maybe battery. i remember when my car did that its cuz my plugs were bad. and make sure you get NGK iridiums.
Old Feb 1, 2007 | 10:24 AM
silvercoupe97's Avatar
Lol, Civic and Eclipse...both cars with motors, but still apples and oranges, lol. You can't compare one to the other.
When was the last time you gave your Eclipse a tune up? Plugs and wires like Jerusry stated, oil change, new battery, and so on.
Old Feb 1, 2007 | 03:24 PM
i got the car tune up about a month or so ago, didnt do the tune up myself. local shop did it for me. those ngkiridiums spark plug, do you order from ebay or auto advance have it. where is the idles screw located? does it need to open up or close it? even i reverse the engine will turn off too.
Old Feb 1, 2007 | 04:30 PM
jerusry's Avatar
it don't matter which way you turn it, just have to have the idle set to about 800rpm's. also, the ngk... you can go to almost any auto parts store and get them... they are usually 6-10 bucks a piece. check your plugs first. if they are not the ngk's...(sometime's shops are cheap bastards and try to put ****ty plugs in there), you might wanna replace them if not ngk.. and if they are looking a little "off-color" then you might wanna replace them. also, what modifications do you have done to your car? maybe it will help trouble shoot.
Old Feb 1, 2007 | 07:48 PM
Nubiebubie_GSX's Avatar
My car does the same when its cold. Or hasn't been started in a day or soo. Battery new, plugs and wires r new, idle fine. I do have a vac leak lol. I just got used to it. On cold cold days i let it run for 5 minutes before i go n e where.
Old Feb 2, 2007 | 02:42 AM
the car have 3" custom exhaust,greddy type s bov and a k&n air filter. and when the car warm up the idle is at 1500rpm. dont know if that is normal range for it.
Old Feb 2, 2007 | 03:00 AM
jerusry's Avatar
i believe you should turn that screw outwards... to make the rpm go down. car should idle at 800rpms. i will get a pic of where the screw is you can tell which way you need to turn it... it will immediatley alter your idle rpm when you turn it. that idle is wayyy to high! ot os located right on your throttle body it is a phillips head screw.. look for it you'll know what i am talkin about.. i dont have a picture sorry.... just use a phillips head to adjust it. adjust it while the car is running...
mikewired
Aug 4, 2019 08:14 PM
TODDK
Dec 22, 2006 11:01 AM
cristalle
Oct 4, 2006 03:36 PM
SaraEclipse19
1st Generation
13
Oct 12, 2005 08:29 PM
99clipsgst
Apr 25, 2005 08:41 PM
