-   -   head being rebuilt..... (https://mitsubishiforum.com/forum/2nd-generation-63/head-being-rebuilt-8664/)
5Tizzle Feb 26, 2006 06:00 PM
Im getting the head on my 95 TSi rebuilt. As long as its off, i may as well throw a few mods in there:). What are the best mods to go in a head? How much hp/tq gain do i get from them?
DSMTalonAWD51 Feb 26, 2006 08:14 PM
RE: head being rebuilt.....
not really any mods you can do otherthan porting and cams. id say dont worry about the porting though, its not really gonna make much of a difference for your power level and you may lose some low end power. you could get some cams but i dont think you are ready for that either.
Sanguinius Feb 27, 2006 04:38 AM
Unless you're going to go with a turbo and build up from there I wouldn't really worry about doing much more to the ead. Cams are porting is great and also possibly bigger valves but there's no point to it unless you're going to beef the lower end and get a good size turbo in there. I'd say look at other bolt on mods unles you plan on doin a full engine job.
93eclipsegsx Feb 27, 2006 10:38 AM
make sure you put a new tensioner pulley on there because i have a 93 gsx and i had my head rebuilt and i didnt put a tensioner pulley on it and the head went again after 80 miles. so $700 down the drain! so i went and bought a whole new head.
slow420a Feb 27, 2006 12:27 PM
Also get it decked. Like dsmtalon said, if your going with the stock turbo or something like a s16g I wouldnt do anything. The money can be spent better in other places.
eclipsed4u Feb 27, 2006 12:35 PM
titianium valves and valve springs.
slow420a Feb 27, 2006 12:36 PM
If the car is stock... then why?
eclipsed4u Feb 27, 2006 02:02 PM
ORIGINAL: slow420a
why not? he has a TSI which will be easy to mod for more HP. might as well do it now since he seems to be rebuilding the engine. even if its stock now, i don't think hes rebuilding the heads if he plans on leaving it stock
Sanguinius Feb 27, 2006 02:23 PM
DEFINATELY a new tnesioner... How could you NOT do a new tensioner dude? I mean I change tensioners every time I change the timing belt...
93eclipsegsx Feb 27, 2006 02:26 PM
yeah i know. i went to the parts store to get all my parts. head gasket set, oil, filter, and everything else, except the tensioner.
bad thing on my part i guess[>:]
