Help????
Help????
Im trying to find a good place to route my 0 ga power cord for my amp. There isn't much room to look behind the fire wall to drill through. Obviously I dont want to drill something important so I ended up letting it hang from the bottom by zip ties. I do not like it. To me it looks cheap and half-*** (which it is). So...anybody know of a good spot to put it? 0 ga is not an easy one to route
RE: Help????
I never found where all the OEM wires went through, so I just drilled all my holes for my wires(stereo, neons, etc) right next to the sterring column on the right, but I made sure that I wouldnt hit anything on the other side, so make sure before you do. Drilling right thjere is pretty easy, (not hard or diff. at all) Then I just attached a Zip tie to the end of the wire and stuck it through the hole. its easy to find and pull through on the other side with that zip tie on.
