Help????
Old May 19, 2006 | 07:14 PM
slvr_eclipse's Avatar
Default Help????
Im trying to find a good place to route my 0 ga power cord for my amp. There isn't much room to look behind the fire wall to drill through. Obviously I dont want to drill something important so I ended up letting it hang from the bottom by zip ties. I do not like it. To me it looks cheap and half-*** (which it is). So...anybody know of a good spot to put it? 0 ga is not an easy one to route
Old May 19, 2006 | 08:10 PM
5Tizzle's Avatar
Default RE: Help????
find wherever the bulk of your cars other wires go through the firewall... you can easily squeeze your wire through there
Old May 19, 2006 | 08:44 PM
i dunno about easily squeeze....the wire is almost an 1in thick
Old May 19, 2006 | 08:45 PM
just drill a hole in it.
Old May 19, 2006 | 11:12 PM
nYOfas's Avatar
I never found where all the OEM wires went through, so I just drilled all my holes for my wires(stereo, neons, etc) right next to the sterring column on the right, but I made sure that I wouldnt hit anything on the other side, so make sure before you do. Drilling right thjere is pretty easy, (not hard or diff. at all) Then I just attached a Zip tie to the end of the wire and stuck it through the hole. its easy to find and pull through on the other side with that zip tie on.
Black widow
Apr 29, 2014 10:30 AM
pablo1318
Jul 10, 2008 06:16 AM
enzo_hashmat2006
Jul 9, 2005 05:02 PM
