HELP WITH 96 ECLIPSE LIGHTING PROBLEMS
i recently noticed that none of my interior lights works...not the gauges, the needles, hvac or the door locks/windows....in addition i have no reverse lights....i looked in the haynes manual and saw that both the interior and reverse lights appear to be on the same circuit.....has any one had this problem? i took out my dash board to see if anything was messed up but everything is correct there....i also replaced the reverse lights and still nothing...someoneplease help before i set my car on fire and buy an acura....
RE: HELP WITH 96 ECLIPSE LIGHTING PROBLEMS
Hi,
I have the same problem. Mine is caused by the stereo system which messed up the whole electical. I am trying to find out how to fix it. Can you tell me where I could locate the fuses for the gauges lights? Are they on the same one as the headlights - my left headlight went down yesterday and does not want to power up, I changed the bulbs but still no effect
there are 2 places to check the fuses. one is under the hood its clearly mark what fuse is to what.the second is on the driver side by your left foot it also will tell you what fuse is to what,check them all.
I just checked the fuses. They both seem in working conditions. When I moved them in and out I fixed the headlights problem so I guess there was a loose fuse for that problem. Still trying to find out what the problem with the gauges is - could the lighting bulb of the gauges be damaged and do you know where it is located?
Thanks,
Svetlin
Thanks,
Svetlin
