help with headers
Old Jan 3, 2008 | 07:26 PM
deathindecay's Avatar
Default help with headers
i have a problem that my rs doesnt pass the smog check because of the headers. . . and they r illegal. . . so i was wondering wat kind of headers should i replace it with and how much am i looking to spend?
Old Jan 4, 2008 | 08:04 AM
tjbiker031's Avatar
Default RE: help with headers
track down some stock headers from ebay. what not passing that is making your headers illegal?
Old Jan 4, 2008 | 09:03 AM
sk8dudety's Avatar
ebay is NOT a performance part store... why on earth would you suggest that? check howellautomotive.com or horsepowerfreaks.com or greddy.com, etc etc... just look around
Old Jan 4, 2008 | 03:06 PM
tjbiker031's Avatar
notice that i said STOCK. in no way did i say get some performance headers from ebay, you'll pass.
now you have two options: one track down some stock headers and put those on untill your car passes, or two, buy a performance header that is legal
Old Jan 4, 2008 | 04:50 PM
any suggestion as to wat i should get? that was my original question. . . and how much would the cheapest nice headers cost around?
Old Jan 4, 2008 | 06:01 PM
sk8dudety's Avatar
like i told you, check pacesetter, greddy, etc... just look around, check howellautomotive.com, summitracing.com, etc
Old Jan 4, 2008 | 06:29 PM
Rob's Avatar
Rob
ORIGINAL: deathindecay
Dude, where are you from? You could propbably get one from the local junk yard for next to free.
Old Jan 4, 2008 | 06:42 PM
are you failing a visual test or is your car literally failing the smog test. Because i cant see just headers make you fail. you might have something else wrong
Old Jan 4, 2008 | 09:55 PM
I Drive Naked's Avatar
ORIGINAL: tjbiker031
From the factory, they're not called headers.
Its an exhaust manifold. Has a catalytic converter attached to it.
Headers delete the primary cat.
Old Jan 4, 2008 | 10:28 PM
tx2u's Avatar
You are right in some ways that headers replaces your primary cats; but only if your talking about long tubes because stock headers and mid-length headers will not replace your primary cats (when we're talking about 4 cat setup). Headers are normally associated with V6, V8, etc motors. This is because a typical header design eliminates the need of a downpipe. You would hook up your headers to a mid-pipe (X, H, Y). On my 01 cobra, I ran hooker long-tubes which eliminated my primary cats.
On the eclipse our setup is like this: exhaust manifold, downpipe, cat, catback/muffler.
Now back to the main issue, what exactly did the inspection station say or noted on your slip?
RyanGT
Apr 10, 2013 09:49 AM
kodred
Sep 26, 2009 10:20 PM
anthobishi03
Jul 20, 2005 04:31 AM
riding03
Mar 15, 2004 11:55 PM
Maverick
Feb 3, 2004 05:20 PM
