Help me hook up new subs
Old Apr 28, 2008 | 08:27 PM
Zfred10's Avatar
Default Help me hook up new subs
I just put in a new 12" kicker sub with amp on it. I hooked everything up. The ground wire is hooked. I hooked everything I needed I think. Im running it to the battery for power and I hooked it up the the back speakers with the one wire. I turn on the music and you can hear the sub, but barely. The amp light is on and everything. It is just not hitting. Please help me out.
Old Apr 28, 2008 | 08:36 PM
9eclipse8's Avatar
Default RE: Help me hook up new subs
on your head unit is your sub turned on, because on mine i have an option to play music with it on or off, also make sure your bass is turned up and not on -6 or something
Old Apr 28, 2008 | 08:56 PM
sk8dudety's Avatar
maybe you have an amp that's not powerful enough...
Old Apr 28, 2008 | 09:04 PM
Zfred10's Avatar
but the amp came with the subs screwed on it. plus it has been in another car before
Old Apr 28, 2008 | 10:23 PM
oh_what_up's Avatar
it sounds like your problem is that you're trying to get the audio signal from the back speakers. You need to get a head unit that specifically has an RCA port for your sub. You can also try raising the "gain" on your sub to see if it helps at all, but I would suggest just hooking it up to radio instead of the rear speaker. Also, do you have a remote wire running from the head unit to the amp? That would also keep the sub from working.
Old Apr 28, 2008 | 10:27 PM
Kaede.Noir's Avatar
^ahhh stole that one from me... yeah.. are you pulling your sub from your beack speakers or actually using the rca's?
Old Apr 28, 2008 | 10:31 PM
oh_what_up's Avatar
hahaha sorry buddy... Thats really the only thing that stuck out to me
Old Apr 28, 2008 | 10:45 PM
Kaede.Noir's Avatar
dont worry... good q though would explain the lower volume specially if the head unit handles the subs separately
Old Apr 29, 2008 | 02:48 PM
Zfred10's Avatar
actually it was just a bad connection. sub works great now just the way it is hooked up
Old Apr 30, 2008 | 02:31 AM
Hyphy Crunk's Avatar
sounds like someone is gonna need a rewire if they hit a bump too hard. [8D]
