helping with Spark PLug installation
Old Feb 12, 2006 | 06:01 AM
GST's Avatar
GST
Default helping with Spark PLug installation
Sorry, i'm kindda noob on this one... -_-.. i took out the spark plug and then i forgot the order and how it goes.. does anybody know how to install spark plug along with the wires? i'm doing this because i recently just bought something to replace the old ones... please help.. now my car dosen't work properly.. whenever i turn on the engine... the exhaust sounds like a choke.... -_-.. feh... man!..
Old Feb 12, 2006 | 07:22 AM
eclipseonjuice's Avatar
Default RE: helping with Spark PLug installation
As far as the spark plugs they just go which every one you want it in. With a Eclipse you will be able to tell which wires will go where because of the distance of the distributer, the longer ones go to 1,4 and the small ones go to 2,3. If you have them like that and its doing that, then switch the wires. Take 2,3 and switch them, and take 1,4 and switch them. I havent done my wires in awhile but i believe mine were labeled. Check on the wires to see if there is a number on it and i believe the distributor also has the numbers.-
Old Feb 12, 2006 | 08:55 AM
GST's Avatar
GST
the number dosen't have labels.. .. a few hours ago i tried, but it shook the engine kindda hard and choke out... it was scary... but i might do it again tomorrow.. or else.. no ride... so... how does it goes?.. 1,4 to the left, and 2,3 goes to the right?
Old Feb 12, 2006 | 01:35 PM
Sanguinius's Avatar
cylinders are numbered from the passengers (right) side of the engine to the drivers (left) side of the engine. 1,2,3,4 1 being on the right (passengers) side and 4 being on the left (drivers') side.
Old Feb 12, 2006 | 03:59 PM
Joel_CA's Avatar
On any 4 cylinder- number 1 is closest to the valve cover (or front of the engine). As far identifying which wire goes where, the cylinder should be identified on the coil or coil bracket or your GST (assuming that based on your tag). You may need to clean off the area to read the stamping. Good LUck!
Joel, CA
Old Feb 12, 2006 | 04:51 PM
DSMTalonAWD51's Avatar
just try swapping wires 2 and 3( the two middle ones) and see if that helps.
Old Feb 12, 2006 | 09:20 PM
GST's Avatar
GST
i think i get it! thanks you guys, prolly cause it was nighttime yesterday, and i couldn't see very well.. imma do it now... THANKs so much if it works!so here it goes..
Old Feb 12, 2006 | 10:32 PM
GST's Avatar
GST
alrite.. so i did it.. but it's the same result.. or prolly poorer.. -__-... should really sucks... i've decided to give it another try and post more on here.. hopefully more specific detail...
here are the images..
or here is some link.. it'll be best if someone label the wires and the holes.. thanks so much.. so stressing now..
http://img.photobucket.com/albums/v2...renity/sp2.jpg
http://img.photobucket.com/albums/v2...renity/sp3.jpg
http://img.photobucket.com/albums/v2...renity/sp4.jpg
http://img.photobucket.com/albums/v2...renity/sp1.jpg
[IMG]local://upfiles/6641/025B39B3154D4946B3090D6CD182513C.jpg[/IMG]
[IMG]local://upfiles/6641/BAAC455D11C743D4A748094CD8DF6823.jpg[/IMG]
[IMG]local://upfiles/6641/9CB1D1A9DEC64D5DB4A173DE5C5AB1F4.jpg[/IMG]
[IMG]local://upfiles/6641/B441EB6430C749A6B796CBE3A5BE7194.jpg[/IMG]
Old Feb 13, 2006 | 01:25 AM
GST's Avatar
GST
okay.. i found it! haha
Old Feb 13, 2006 | 10:20 AM
found what. What was the problem?
