Heres a question for you
A few years ago I picked up a gsx that was all torn apart and in pieces. For many different reasons I still haven't been able to finish it (mostly because I wanted to build it up to where I want it before I finish). Regardless, I've decided to just finish it with stock pieces just so I can get it running. Currently I'm running PTE 880cc injectors, and have gotten my ecu chipped from DSMChips.com to compensate for these bigger injectors. If I run a stock turbo and an safc can I still use these injectors? Or should I convert back to 450's?
Heres another question, since the ecu is reprogrammed for the 880's, will I even be able to run 450's on it without getting another ecu for the time being?
