Hey Need Help.
Old Dec 13, 2007 | 07:15 PM
Default RE: Hey Need Help.
Well if you dont have a check engine light, and your boost gauge shows normal, i dont know what to tell you.
Old Dec 13, 2007 | 07:54 PM
Gregory's Avatar
Did you do the boost leak test yet? Also, what gear are you in when you are experiencing it? What RPM are you at when it finally kicks in? MPH has almost absolutely nothing to do with how the engine is running. Are you saying you redline through first and second with no boost, and then it finally kicks in in third? Need more information to help.
Old Dec 13, 2007 | 08:05 PM
CelciuS209's Avatar
Yea just like that but its a automatic. how do i do a boost leak check, and no engine light is on yet.
Old Dec 13, 2007 | 09:43 PM
Gregory's Avatar
oh automatic? What is your boost guage reading? Like it drive up to redline while reading 0 boost? and then at 40 it just kicks on? Give the best description you can of the problem.
You need a boost leak tester to do a boost leak. It's a simple coupler with a cap and valve stem. You take off your intake and hook it to the turbo inlet, and pump in the psi of boost you run, and spray soapy water on all areas with possible boost leaks. It's often a good idea to start with just the throttle body, and work down from there.
Old Dec 13, 2007 | 10:20 PM
CelciuS209's Avatar
well yea its a auto. LOL but when i drive normaly u can hear the turbo spining barley and it goes to about 3-6 psi and then when i floor it it dont go anywhere then few seconds later it starts spinning normaly but b4 when i floor it turbo kicked in right away and at 15psi
Old Dec 13, 2007 | 10:22 PM
CelciuS209's Avatar
and yes when i floor it it goes to around 5-6 rpms going no where.
Old Dec 13, 2007 | 10:24 PM
Thats just due to your stock turbo being a piece of ****. Thats nothing out of the ordinary. Your problem is speed-itus. Common : ) Time for a 16g
Old Dec 13, 2007 | 10:26 PM
Oh, half your problem is that its auto, thats generally slower. Another thing that may be contributing to this is crappy plugs or wires. Change the plugs with NGK Classics and change your wires with good ole Mitsubishi wires.
Old Dec 14, 2007 | 01:04 AM
CelciuS209's Avatar
witch wires are u talking about?
Old Dec 14, 2007 | 03:40 AM
sk8dudety's Avatar
stock replacement wires that you can get from auto zone or advance auto
