Hi RPMs
Old Oct 8, 2004 | 04:53 PM
Flipz's Avatar
Default Hi RPMs
Hi,
I just bought a 1996 Mitsubishi Eclipse GS Spyder and wanted to register it these days but when I went to SMOG check they said they could not run it because it is running on too high RPMs and indeed upon accerating from 0 to 40 it goes up to 3000 RPM. I am going to get it to service but I was wondering whether anyone knows what might be causing it so I could tell it to the service instead of trying to figure it out.
Thank you in advance and I will be looking foward to your opinions.
Regards,
Svetlin
Old Oct 8, 2004 | 09:54 PM
1398spdr's Avatar
Default RE: Hi RPMs
could be the timing is advanced..... also check the throttle cable, make sure it isnt too tight.........
Old Oct 10, 2004 | 02:47 PM
Flipz's Avatar
Default RE: Hi RPMs
Could it be something connected with the timing belt. I just bought the car and this belt hasn't been changed yet and it is on 81K miles?
Old Oct 10, 2004 | 05:48 PM
1398spdr's Avatar
Default RE: Hi RPMs
not sure, but if your sure the belt has never been replaced now would be a good time to replace it and the water pump, seems like everyone says theyve never had it replaced and within about a month or two theyre back sayin the belt broke and blew the engine.......... and if the problem is the timing they can set it again when they replace the belt.... it costs a good bit of money, but its better than blowing your engine............
Aight76
Oct 13, 2006 06:51 PM
wulls1313
Aug 21, 2005 12:54 PM
2001eclipse
Jun 19, 2005 05:31 AM
darkman0127
Jun 7, 2004 02:31 PM
97Eclipse
Oct 23, 2003 01:53 AM
