HID question
Old Aug 14, 2007 | 05:29 PM
justnobody's Avatar
Default HID question
hey whats up everyone? the owner before me had projectors on his eclipse, i wanna get some HIDs cause the lights are too dim, is it possible? my friend told me its not cause if I do put the H1 HID bulb in there its gonna melt the housing or something? am i better off just getting stock headlights from a junkyard and then get the HIDs?
Old Aug 15, 2007 | 06:57 AM
tjbiker031's Avatar
Default RE: HID question
or you can keep your projectors and get higher wattage bulbs from the parts store...
Old Aug 15, 2007 | 08:06 AM
silvercoupe97's Avatar
ORIGINAL: tjbiker031
A big no, no. Higher wattage bulbs are what cause wire insulation to melt and cause issues such as fires from the higher power draw. If the stock bulbs are 55 watt bulbs, use 55 watt bulbs or redo the wiring with thicker gauge wires.
ORIGINAL: justnobody
Folks do this all the time, replacing the halogen with HID kits, on their stock headlight housing without melting anything. It won't melt the housing, high wattage bulbs will though, if it doesn't fire up the wires first.
BTW, H1 bulbs are foglight bulbs, that's why the light output sucks. Well, that and they obviously aren't real projector bulbs/lights.
Old Aug 15, 2007 | 09:49 PM
antlip's Avatar
Dont HID bulbs actually run cooler than standard light bulbs for head lights? The HID bulbs will spray light all over in the stock housing. They have ways to modify the stock housing to help project the light in the right direction. I am sure if you do a search online someone has it all done with picture by picture instructions. If you put HID lights in a real crappy head light housing it is possible to have worst lighting than before since the light wont be projected in the right direction and be wasted possibly pointing down at your bumper. My opinion is to just get some clean stock housings and put in the silverstar bulbs. They are night and day with the stock bulbs.
[IMG]local://upfiles/6177/A6ECB7AC44814C96BA07F6DF62EC425D.jpg[/IMG]
Old Aug 16, 2007 | 02:22 AM
Natedogg89's Avatar
ORIGINAL: antlip
Thats what i'm doing. Going to pick up the high and low beams here sometime soon
onebadmofo
Jun 5, 2014 07:13 PM
RA2625
Apr 9, 2013 01:45 AM
JRK5892
Apr 2, 2013 10:17 AM
kakaraj
4th Generation
Jan 5, 2009 04:13 PM
minkoj0101
Jun 18, 2003 11:51 AM
