Hoses...?
Old Mar 11, 2007 | 09:06 PM
BoostNightRanger's Avatar
Default Hoses...?
Ok this may soon extremely stupid and careless but I was just as surprised as anyone else would be.I was changing the air filter when I looked down and say two ends that looked like tubing fit on the end of them. Sure enough down laying deeper in the engine bay were two tubes. One connected from the air intake tubing to the top of the engine and the other from theintake tubing tosomewhere beneath the battery. I'm not sure how long they were disconnected but the car has been driving fine. I reconnected them of course but if anybody has any idea as to what they are and what they do please let me know. I have a 91 Talon TSi fwd. Thanks.
Old Mar 11, 2007 | 09:21 PM
Default RE: Hoses...?
Its just the run off for the valve cover. If you want to eliminate that. (and stop oil from gettin into your intake) then just get an oil catch can.
The hose is normal
Old Mar 11, 2007 | 10:41 PM
silvercoupe97's Avatar
I believe the hose that goes under the battery is the breather hose for the EGR.
The valve cover's breather hose can be connected to a fuel filter too, instead of a catch can. That way, instead of paying $50+ on a catch can, you will only spend $7 and you still keep oil out of the intake. You can buy a breather filter too, that might keep oil out of the intake but you get oil all over the engine bay instead.
Old Mar 11, 2007 | 10:55 PM
Dude you can make a catch can out of a freakin coke bottle
Old Mar 11, 2007 | 11:16 PM
ORIGINAL: Sebba
That is true, but I'd rather spend $7-$10 for something that will keep the hoses in stock configuration with a filter on it than have a coke bottle with a hose rammed through the lid sitting in my engine bay.
Frugal is one thing, cheap and/or ghetto is another.
Old Mar 11, 2007 | 11:33 PM
Ok. The filters get clogged and nasty though
Old Mar 12, 2007 | 12:04 AM
cologsx's Avatar
I tap the exhaust and run the vent hose down to the exhaust pipe. It helps vent crank case pressure, you don't get oil in the engine bay, you don't have a coke bottle hanging around, andyou don't have a filter to get clogged.
Old Mar 12, 2007 | 01:56 AM
antlip's Avatar
What ever you do dont put a breather filter on your valve cover. After time the filter will get oil soaked and spray oil all over your engine bay making a really nasty oily mess. Unless you plan on replacing that breather filter alot so you dont risk oil soaking it and spraying your whole engine bay with oil, I would buy a catch can.
Old Mar 13, 2007 | 12:58 AM
ORIGINAL: cologsx
Oil and hot exhaust, somehow that just doesn't sound safe to me.
Old Mar 13, 2007 | 01:06 AM
cologsx's Avatar
Use a 1 way check valve, if you have that much oil venting out of the motor you have bigger problems. I don't know, I haven't burned down my cars yet and I've done this on 4 drag cars, 3desert cars,and 2 daily driver hot rods, mine and my wifes.
EDDIE138301
Mar 14, 2011 06:21 PM
GTS 2.4
Dec 1, 2010 04:00 PM
rico
Sep 28, 2008 01:14 AM
Sparkplugs.com
Aug 22, 2007 03:14 PM
FatalJRA
Dec 19, 2004 06:03 AM
