How big am i
RE: How big am i
I run a 225/40/R18 on mine. It's lowered about 2.5-3 inches and will just scuff the rear tires on a really hard bump. My wheels are 7.5 inches wide. hope this helps.... almost forgot, you HAVE to make sure the offset is correct for your car otherwise they will rub either on the fender or the inner suspension components.
RE: How big am i
how big can you fit... well in all honesty, you can go as small as a 200/20/18, or as big as a 225/75/18.
just depends on how much you want to rub, and how lowered you are.
In all seriousness, we need more information here. Like how low is your car compared to stock, (how many inch drop)
how wide are your tires,
do you have anything adjusting the camber,
do you intend to lower it later.
blah blah blah.
blah blah blah.
RE: How big am i
ORIGINAL: soundcolor
RE: How big am i
200/20/18
The tires aspect ratio does not get measure in incriments of 0's.
goes in 10's starting at 5.
Exp: 205, 225, 245
And the aspect width on any tire does not go lower than a 30.
exp: 255/30/20.
A moderatley wide tire and a low sidewall.
Probally the best 18' to run would be a 215/40/18 on an 18x7.5 rim.
the tire would be wide enough for the rim, w/o any overedge, and still be low enough to clear the suspension as long as the offset of the rim is correct for the vehicle.
