How do you reset 420a timing?
Old Jun 23, 2007 | 01:33 PM
willdue's Avatar
Default How do you reset 420a timing?
My friend scanned my car, and it said the timing was at like 8, and he said it should be at 13-15. is this easy to do, can I save some money, or does a shop need to rip me off?
Old Jun 23, 2007 | 04:09 PM
Kaede.Noir's Avatar
Default RE: How do you reset 420a timing?
matching the pulleys together or the flywheel to the crank, look for the lil arrows physically engraved on the engine and pulleys
Old Jun 23, 2007 | 05:40 PM
willdue's Avatar
is there step by step on this? I dont wanna mess it up...Is it easy, how long should it take?
Old Jun 23, 2007 | 05:55 PM
racerx55's Avatar
if your friend is using a computer scanner to read timing, it will vary depending on temp, RPM, load, where did your friend get this idea? that just shows where the ECU is firing at.
you cant adjust it on a 420a, its computer controlled , unless your timin belt has jumped a tooth (and it would run like crap)
Old Jun 23, 2007 | 06:15 PM
willdue's Avatar
it does run like crap, it has no damn power at all.
My IAT temp was at 222 or sumin like that lol. but its not throwing codes anymore, so i assume thats fixed?
Old Jun 24, 2007 | 12:18 AM
I Drive Naked's Avatar
He needs a timing belt.
And possibly some head work foer bent valves.
Remove the valve cover and turn the crank until the get to top dead center.
The timing marks should then be aligned. Install new timing belt, and replace the idler and tensioner pulleys.
Old Jun 24, 2007 | 02:08 AM
silvercoupe97's Avatar
The timing is electronically controlled. You would have to really knock the motor around one good time to skip a tooth or more. What makes you think that you knocked it out of timing?
Your IAT shows hot, do you have an aftermarket short RAM intake? If you do, then your motor is sucking up the hot air in the engine bay and can make your car run poorly...not by itself though. So, there could be something down the line that is out of whack. When you rev the motor, while holding revs, how does the motor sound? When was the last time this motor had a tune up? There's just so much more to consider before jumping to jumped timing.
Old Jun 24, 2007 | 01:02 PM
willdue's Avatar
Cause the guy at the shop told me it needed to be?
No, it has a CAI, AEM. I juss replaced wires and plugs not to long ago, along with fuel filter, fuel injectors.
My tensioner pulley does squeek? But i was told that wouldt make a diff?
Old Jun 24, 2007 | 01:06 PM
willdue's Avatar
its wierd though, today driven home, i was steady at 3k RPM and it juss kept like stuttering. And its not a clutch slip.
jallen28144
Sep 7, 2013 12:40 PM
frankvig1
Apr 10, 2012 11:27 AM
slow420a
Feb 19, 2008 10:00 PM
halfasss101
Sep 4, 2007 02:35 PM
racerx55
Jan 16, 2007 02:24 PM
