How much can I boost my car up
Old 05-01-2006 | 01:09 AM
B.e.R.a.T's Avatar
Default How much can I boost my car up
hey guys
I finally got my gauges in (Boost/Vacuum and Air/Fuel). I bought a greddy rs BOV with recirculation kit. I am buying the MBC tomorrow morning. I have a cold air intake but other than that my car is all stock. How much could I turn my boost up. How many PSI my car will handle without going lean on the fuel. PLease let me know.
Old 05-01-2006 | 01:27 AM
eclipsed4u's Avatar
Default RE: How much can I boost my car up
14-15
Old 05-01-2006 | 02:25 AM
5Tizzle's Avatar
15 is the highest you should go in terms of safety, but i believe fuel cut will not happen til 17 or 18
Old 05-01-2006 | 02:58 AM
B.e.R.a.T's Avatar
so if I run 12-13 I will be alright with everything.what should I change to go up. also am I going to be able use everything if I upgrade my turbo.
Old 05-01-2006 | 03:37 AM
5Tizzle's Avatar
no its safe to set it at 15. and no, if you upgrade your turbo you will need to upgrade your fuel system to run higher psi.
Old 05-01-2006 | 03:50 AM
B.e.R.a.T's Avatar
how many psi is the stock gst do u know?
Old 05-01-2006 | 10:09 AM
RCJr9186's Avatar
i believe a stock gs-t and gsx run 6-7 if you take of the restrictor it takes it up to 8 or 9. you should be thinking about an exhaust around this time.
Old 05-01-2006 | 11:17 PM
B.e.R.a.T's Avatar
does anybody know how much boost the stock turbo runs please let me know
Old 05-02-2006 | 12:10 AM
DSMTalonAWD51's Avatar
stock is more like 11-12, you can turn it to 16 with a mbc
Old 05-03-2006 | 12:46 AM
n2daizo123's Avatar
11-12 stock. the turbo is limited to 17psi max.
Quick Reply: How much can I boost my car up
