How much can I boost my car up
Old May 1, 2006 | 01:09 AM
B.e.R.a.T's Avatar
Default How much can I boost my car up
hey guys
I finally got my gauges in (Boost/Vacuum and Air/Fuel). I bought a greddy rs BOV with recirculation kit. I am buying the MBC tomorrow morning. I have a cold air intake but other than that my car is all stock. How much could I turn my boost up. How many PSI my car will handle without going lean on the fuel. PLease let me know.
Old May 1, 2006 | 01:27 AM
eclipsed4u's Avatar
Default RE: How much can I boost my car up
14-15
Old May 1, 2006 | 02:25 AM
5Tizzle's Avatar
15 is the highest you should go in terms of safety, but i believe fuel cut will not happen til 17 or 18
Old May 1, 2006 | 02:58 AM
B.e.R.a.T's Avatar
so if I run 12-13 I will be alright with everything.what should I change to go up. also am I going to be able use everything if I upgrade my turbo.
Old May 1, 2006 | 03:37 AM
5Tizzle's Avatar
no its safe to set it at 15. and no, if you upgrade your turbo you will need to upgrade your fuel system to run higher psi.
Old May 1, 2006 | 03:50 AM
B.e.R.a.T's Avatar
how many psi is the stock gst do u know?
Old May 1, 2006 | 10:09 AM
RCJr9186's Avatar
i believe a stock gs-t and gsx run 6-7 if you take of the restrictor it takes it up to 8 or 9. you should be thinking about an exhaust around this time.
Old May 1, 2006 | 11:17 PM
B.e.R.a.T's Avatar
does anybody know how much boost the stock turbo runs please let me know
Old May 2, 2006 | 12:10 AM
DSMTalonAWD51's Avatar
stock is more like 11-12, you can turn it to 16 with a mbc
Old May 3, 2006 | 12:46 AM
n2daizo123's Avatar
11-12 stock. the turbo is limited to 17psi max.
