How much horsepower can at regular 1997 gs achieve?
Old Nov 8, 2006 | 10:41 AM
RCJr9186's Avatar
Default RE: How much horsepower can at regular 1997 gs achieve?
yup, tha'ts what i'm piecing together right now, injectors, MSD, boost gauge, wideband, greddy emanage ultimate,
Old Nov 8, 2006 | 03:40 PM
97eclipseboy's Avatar
thats good to hear..ill go with the Na parts for now. i will eventually either turbo it too, however..will if i install a turbo kit, will it pass emission?
Old Nov 8, 2006 | 03:49 PM
Yes with a cat
Old Nov 8, 2006 | 04:02 PM
RCJr9186's Avatar
x2 with Sebba, here in good ole South Carolina we dont have emissions laws so a lot of people just run straight 3' pipe straight back, sounds good, LOUD turbo spool, and better flow. so you can check your stat emissions laws. and if you have to use a cat, don't fret on the HP loss... in an article of Import Tuner a month or so ago there was an article with the difference between a cat, high flow cat and test pipe. . . the difference was 1hp gain each step up, so you won't be losing that much.
Old Nov 8, 2006 | 04:05 PM
ORIGINAL: RCJr9186
did they have proof showing it because i dont know how much i believe only a 2hp gain between stock cat and test pipe. seems kinda screwed up, especially when you start running higher boost and bigger turbo's
Old Nov 8, 2006 | 04:20 PM
RCJr9186's Avatar
yea they had the dyno runs to prove the differnces... from stock cat - high flow cat = 1hp gain and from high flow cat - test pipe = 1hp gain. i want to say it was in the november edition of Import Tuner, i think it had an orange sylvia on the front w/ carbon fiber hood. i sent the magazine and 5 others to a friend of mine in Iraq so i don't have it anymore. i think it was on a turbo'd integra pushing like 8-10 lbs.... i can't be sure though. but yea on the same car running the same boost, it was 2 hp gain.
Old Nov 8, 2006 | 04:32 PM
thats kinda small boost though. IDK i guess it will really depend because to use a stock cat that mean you MUST use a smaller downpipe, so already there is more restriction. And i think the changes in HP is gonna be very boost dependant
Old Nov 8, 2006 | 04:33 PM
I never really thought those high flow cats were all that great anyway. They are pointless.
Old Nov 8, 2006 | 05:33 PM
ORIGINAL: Sebba
i dont disagree with that but i think going to a test pipe should give better gains
Old Nov 8, 2006 | 06:29 PM
Ofcourse
