how much power before crankwalk?
Old Jun 18, 2006 | 08:19 PM
paintballproam's Avatar
Default how much power before crankwalk?
On a second gen, how much power can i get out of it safely? At what point should i swap in a 6 bolt?
Old Jun 18, 2006 | 09:47 PM
Default RE: how much power before crankwalk?
wont make a difference about the power thats is going through the crank but the stock engine can hold 400 and starts to break apart at 450.
Old Jun 18, 2006 | 10:24 PM
ok cause i wanted to push 350hp
Old Jun 19, 2006 | 12:40 AM
RCJr9186's Avatar
if you plan on building up your 2g the easiest way is to just swap out the 6 bolt in the begining so you don't risk having the crank walk and screw all the beautiful work you have just put into your car!
Old Jun 19, 2006 | 10:53 AM
eclipsed4u's Avatar
ORIGINAL: RCJr9186
agreed. there is no set limit to a power threshold that causes crankwalk. it just happens. i am sure that it has happened on stock engines.
Old Jun 19, 2006 | 11:28 AM
yea its really not the power, its how its driven. But of course adding power does add more of a chance.
Tennysballs
Apr 25, 2012 11:58 AM
Schwitzer Turbo
16
Aug 15, 2007 01:28 AM
paintballproam
Nov 2, 2006 07:38 PM
ruserge88
Apr 28, 2006 04:08 PM
bagz
Apr 27, 2006 08:03 PM
