IAC problem
Old Oct 3, 2007 | 04:32 PM
tjbiker031's Avatar
Default IAC problem
ok so ever since i bought the car every so often my car would throw up a code about a malfuction of my IAC, and i would reset the computer and it would be fine for a while and come back . well i found a decently used one cuz i cant afford a new one for now and i put it on today and it started to idle like crazy around 1500 RPM's sotook it out and replaced it with my original one and now she just idles at 1500, drops down slowly to 1100 and back up to 1500 RPMs. am i doing something wrong or are both of my parts faulty now?
Old Oct 3, 2007 | 05:09 PM
Default RE: IAC problem
Try resetting the ECU. If that doenst work, then maybe they are both messed up
Old Oct 3, 2007 | 05:11 PM
tjbiker031's Avatar
yea i tried to reset the ECU when i put the old one back in......you gotta disconnect the battery and step on the brake for a few seconds right to reset it right?
Old Oct 3, 2007 | 05:12 PM
With the key in the ignition/turned to the on position
Old Oct 3, 2007 | 05:49 PM
tjbiker031's Avatar
oh ok, well i just swaped them around and they run about the same, the original one i had just idles high with a slight surge, so i guess im going to have to buy a new one and they're both f**ked now
Old Oct 3, 2007 | 06:30 PM
what was the exact code # that your were getting?
Old Oct 3, 2007 | 07:05 PM
tjbiker031's Avatar
P0505- Idle Control System Malfunction
Old Oct 3, 2007 | 07:27 PM
get435's Avatar
This can have many differant causes i am currently delaing with this myself. It can be anything from a simple boost/vac leak, ISC, EGR, FIAV, BISS, or MAF. you will need to runa few test before replaceing parts. I would check for Vac leak. here is a idel sure writeup that is very good.
-> Surge
-> http://www.vfaq.com/mods/wayback/BradBauer/engine/surge.html
Old Oct 3, 2007 | 07:48 PM
ISC - No it wouldnt cause the revs to jump at all.. it would just idle like *****
EGR - Would throw the EGR code
FIAV - First idle air valve??? Not familiar, cant say
BISS - Again, wouldnt cause the revs to jump.. just idle like *****
MAF - Possible actually... but why would it throw the IAC code?
Old Oct 3, 2007 | 08:13 PM
tjbiker031's Avatar
well its weird cuz my car idled fine before i messed with the IAC'sand now even with the original part back on there its idleing at 1200-1500
