IAC problem
Old 10-05-2007, 06:32 AM
Default RE: IAC problem
its still probably just the iac is bad. And maybe you forgot to put a vaccum line on?
Old 10-05-2007, 02:24 PM
tjbiker031's Avatar
its weird how the one that was just working is acting up too.......i didnt take off any vacume lines.....but ill check.
ok so what are some things i can check/clean to start to narrow things down?
Old 10-06-2007, 05:02 PM
tjbiker031's Avatar
well after some research i think its most likely either my IAC isnt working properly and/or thethrottle body is dirty and/or sticking letting too much air and causing the surge. soon as it stops raining like it has been for the last week i can pull my intake apart and check my IAC. let me know if you have any other idea of what it could be.
Old 10-07-2007, 05:26 PM
tjbiker031's Avatar
ok so i was thinkin today cuz i was doing some research on the good 'ole internet and came acrossa potential solution.it said if you changed out the ISC and didnt replace, or atleast inspect the o-ring, that if it got damaged during removal that that could be the cause of idle surge, even if a new ISC is installed. is that true?
Old 10-08-2007, 09:05 AM
tjbiker031's Avatar
OK i think i fixed the surge! I messed with the BISS and got her down to 800. i can go down more but im not sure the proper speed for idle. some crack head that lives in my apt. complex said thats its suppost to be around 750, is he correct? And is it normal for when i turn the A/C on for the idle to bog down?[/align]
Old 10-30-2007, 07:41 PM
well all i fixed this error on my car. It was the IAC got a new one from napa for $66
Still had idle surge after the biss was adjusted because it was almost falling out only thing i can think of is it vibrated loose.
700-800 is the correct idel this error is triggered buy being off target rpm for more than i believe 20 sec.
5Tizzle
10-05-2006 01:31 PM
5Tizzle
08-03-2006 06:49 PM
00GalantMan
04-09-2006 01:24 AM
damnitsmark
03-29-2006 09:38 PM
brandoN^gsT
01-29-2006 08:40 PM
Quick Reply: IAC problem
