idle issues
Old Jul 5, 2006 | 04:25 AM
oh_what_up's Avatar
Default idle issues
hey guys I'm having some issues over here. Not all the time, but the majority of it, my car idles like $#!T. The RPMs will start to dip and threaten to stall. Sometimes it even does. I've replaced the plugs, i have magnecor wires, and I just replaced the IAC today. Could I have the SAFC tuned too lean at idle? or does someone think its something else? Thanks for any and all help.
Old Jul 5, 2006 | 07:07 AM
Default RE: idle issues
are you venting a bov?
Old Jul 5, 2006 | 10:37 AM
tidus10's Avatar
unplug your battery for 12-24 hrs if you could....give the computer time to reset itself... and if that doesnt work.. check for a vacuum leak...
Old Jul 5, 2006 | 11:23 AM
ORIGINAL: tidus10
it onlytakes a few minutes to resett the battery Tidus
Old Jul 5, 2006 | 04:29 PM
oh_what_up's Avatar
Thanks for all your help guys. I tried resetting the battery but it hasn't helped. Sebba, I am venting the bov but I have a Gm maf in a blow through set up so that shouldn't make a difference. On top of the idle problem, when I'm boosting at WOT, it usually feels like its hitting a wall and it stops building boost and speed unless i let up on the throttle. Today, however, it pulled all the way to redline throughout every gear. Was there a blockage that worked itself loose or is there something else that it could be? Thank you all soo much for your help.
Old Jul 5, 2006 | 04:41 PM
well you shouldnt even be tuning your idle with the safc. And i dont really se that being the problem either. Is the thing up high like a hard jerk (fuel cut, if you know what i mean by that). Could be your tune for the WOT problem. But for the idle make sure your not tuning the low thottle rpms (zero them out), i dont think that will fix it, but depending on your tune it might. Check around for a vacuum leak as well. What i really think could be causing all of this though is a leak. Maybe the intercooler piping or intake piping came loose. I would definetly at least start there.
Old Jul 6, 2006 | 01:41 AM
oh_what_up's Avatar
Thanks for your input my man. I had to tune the low throttle because it was running too rich. I couldn't even drive it because it was so rich. I really do need to check the vacuum lines, but the intercooler piping and intake tube are tight with no leaks. I'll try to richen the idle set a little bit as well as the low throttle and I'll let you know. Thanks again for your help.
Old Jul 6, 2006 | 09:19 AM
you should never have any reason to tune the low throttle because there isnt even a constant a/f ratio that can be read at it.
Old Jul 6, 2006 | 03:31 PM
BrunoBoy650's Avatar
ORIGINAL: oh_what_up
those are the same exact problems with my 92 gsx.........the EXACT same problems. i turned the idle up and even though it goes up and down, it doesnt go down far enough to cause it to stall.
Old Jul 6, 2006 | 09:06 PM
Sanguinius's Avatar
If it's going up and down like it can't find a good spot to stay at then it's likely the IAC motor.
