idle problems
idle problems
ok so heres the deal. . i have a 98 gs-t 5 speed. the check engine light came on and i went got it tested and it was the throttle position sensor. payed the 150 bucks to get it. put it in and now the car will die after the throttle comes back down from acceleration and isnt even wanting to idle at all and if it does its at about 100rpm. just got this car like a month ago anyone know whats goin on? thanks
RE: idle problems
i just tried that, at idle it will bounce from about o-500rpm it will be at 500 and then die and the momentum in the crank will start it back up and it will do this untill it levels off at about 100rpm, should i just adjust the idle control screw, the only reason i havent yet is because it ran fine with the way its ajusted now be4 i had the problems
