idle problems
Old Nov 6, 2007 | 01:02 PM
19gst98's Avatar
Default idle problems
ok so heres the deal. . i have a 98 gs-t 5 speed. the check engine light came on and i went got it tested and it was the throttle position sensor. payed the 150 bucks to get it. put it in and now the car will die after the throttle comes back down from acceleration and isnt even wanting to idle at all and if it does its at about 100rpm. just got this car like a month ago anyone know whats goin on? thanks
Old Nov 6, 2007 | 01:07 PM
jason clipse's Avatar
Default RE: idle problems
was the new sensor new or used...?
Old Nov 6, 2007 | 01:09 PM
19gst98's Avatar
brand new from auto-zone
Old Nov 6, 2007 | 02:21 PM
Dissconnect the battery for a min. Then put the key in the ignition to drain any excess power and start it back up.
Old Nov 6, 2007 | 02:46 PM
19gst98's Avatar
i just tried that, at idle it will bounce from about o-500rpm it will be at 500 and then die and the momentum in the crank will start it back up and it will do this untill it levels off at about 100rpm, should i just adjust the idle control screw, the only reason i havent yet is because it ran fine with the way its ajusted now be4 i had the problems
Old Nov 6, 2007 | 04:05 PM
bestwiseguy's Avatar
When you installed the new tps sensor did you make sure you had it set to the right ohm level.
Old Nov 6, 2007 | 04:09 PM
19gst98's Avatar
no i just swapped it and disconnected the battery and reconnected it
Old Nov 6, 2007 | 04:13 PM
you have to adjust the tps to read between certain ohm levels, i cant remember what it is off the top of my head. Can one of you guys help me out.
Old Nov 6, 2007 | 04:18 PM
19gst98's Avatar
yeah i just figured when u take the battery off and reconnect it that the computer would communicate with it, it was a direct oem replacement
Old Nov 6, 2007 | 04:22 PM
Yes but when you install it you have to tilt the tps sensor one way or another to adjust the readings, if its not correct it will not work properly.
