idle problems
Old 11-20-2008, 07:23 PM
Jarreddl's Avatar
Default idle problems
alright well i just started driving my car again (its been about 2 months) it starts fine and when i first start it up it will idle fine but once i rev it or go somewhere and stop it idles at about 500. when i brake and come to a stop it drops even below 500 rpms. sometimes it will even die. any help would be appreciated. thanks
Old 11-20-2008, 08:14 PM
estraw's Avatar
Default RE: idle problems
possibly a vacuum leak. take a can of carb cleaner when its acting up and spray it around the manifold (with the car still idling), and if its runs better while your spraying, then its a vacuum leak
Old 11-20-2008, 08:45 PM
Jarreddl's Avatar
what else do you think it would be? just wondering. i havent tried that yet though
would it be safe to drive it or should i try not to drive it?
Old 11-21-2008, 03:25 AM
silvercoupe97's Avatar
Sounds like a vacuum issue to me too. Check your hoses. I don't mean just look at them either; you're supposed to pinch them to check for cracks.
Old 11-21-2008, 02:55 PM
Jarreddl's Avatar
do you think this could be my problem? its been like this sense i have had the car though.
Old 11-21-2008, 03:44 PM
ORIGINAL: Jarreddl
Well, that would cause an issue right there. I would check the rest of the hoses and connections if you haven't already. You can do a few things to take care of that; one is to use plasti-weld and another is to buy one off of ebay or junk yard.
What did that hose connect to? The PCV, brake booster...?
Old 11-21-2008, 04:52 PM
Jarreddl's Avatar
im not sure what everything is called so i couldnt tell you exactly but ill try.
thats the stock air filter hose and that little hose connects to the part right behind the spark plugs.
Old 11-23-2008, 10:19 PM
Jarreddl's Avatar
well i found out that that isnt the problem. im getting closer and closer to thinking that it is a vacuum leak which if it is im going to let a professional do that one :P
thanks for all the help though.
Old 11-23-2008, 10:25 PM
the pcv valve?
Old 11-23-2008, 10:54 PM
Jarreddl's Avatar
whats that? or where is it actually
Quick Reply: idle problems
