Installing boost gauge/controller
Old Aug 3, 2007 | 12:44 AM
silvercoupe97's Avatar
Default RE: Installing boost gauge/controller
ORIGINAL: Natedogg89
Silver, where is that, passanger side firewall under where the battery is?
Yup. My battery is in the trunk and my EGR system is in a bag in the house closet, lol. As you can see that area is pretty open after removing all of that stuff and that's where my alky injection is going.
ORIGINAL: dorian7
OK so now I was wondering if anyone could tell/show me where I am supposed to connect the boost hose too, it says manifold pressure. I got the wires routed under the battery in the firewall.
(Facing the firewall from the front of the car) on the right side of the intake manifold, there's a vacuum line that goes to the stock fpr, that's where you tee into.
Do you see the black tube that is coming out of the left side of that solenoid? That's the fpr. At the end of the black tube is a white T, going down and through the steering wheel boot is the vacuum line that goes to the boost gauge. The other hose (the red one) goes back into the intake manifold.
Here's the rest of that pick.
http://members.shaw.ca/dsm.1000q/Engineprimer/2G/Q2.htm
Old Aug 4, 2007 | 12:32 AM
dorian7's Avatar
Ok I got the Tru-boost gauge, I am not going to install the selinoid untill I get the UICP and 1G bov installed. The gauge is reading that I am running about upper 12's to 13psi. Everything is stock except intake and exhaust. Is this right?
Old Aug 4, 2007 | 01:24 AM
That is about right for stock pressures.
Old Aug 4, 2007 | 01:43 AM
dorian7's Avatar
huh I was told stock pressure was like 9-10... Oh well. So after I get teh UICP and the BOV I am thinking that I am going to run about 16psi, is this a pretty safe pressure for the stock turbo?
Old Aug 4, 2007 | 02:35 AM
1G cars have a stock boost pressure of 8-12 psi. 2G cars have 10-15 psi. The service manual allows lower pressures, but those are rarely seen in actual vehicles.
http://members.shaw.ca/costall/1000Q/
Stick with 15psi too.
Old Aug 4, 2007 | 07:09 PM
dorian7's Avatar
Ok so now we are on to the good stuff, here are some settings that I am not familiar with and if someone could explain them along with suggest a good setting that would be sweet!
It says spring pressure (SPr-2.00) waste gate pressure. Boost selonoid will open from 1psi untill boost level exceeds the selected value. This valve can be adjusted to reduce lead in boost spikes or rudce spool time.?
Boost setting a: (AXX-A10) Set the output duty cycle (10%-90%), the duty cycle is displayed as "AXX" ?
Old Aug 4, 2007 | 07:28 PM
Lol, good luck with that. I know you already have it, but man, this is why you stick with the traditional MBC. If you did, you would have had this already licked and you'd be boostin' down the road, lol.
Sorry bro, I love gadgets, but more so than none, simple is good.
Here's what I would do. AEM has a forum that shows you how to set this stuff up and what this that and the other means, you should check it out bud and good luck with setting that up. I wouldn't imagine it to be difficult. Take a bottle of water and aspirin with you to help you get that thing setup
jsjones_usmc
Dec 18, 2008 02:56 PM
burnmyeyes
Jan 2, 2008 09:04 PM
2nd g eclipse gst
May 12, 2006 06:19 AM
Knaackers
Jun 25, 2004 06:01 PM
