internal vs external
Old 01-16-2008 | 01:51 PM
c577's Avatar
Default internal vs external
what are the pros. cons. of internal and external wastegates?
[align=left] [/align]
Old 01-16-2008 | 05:07 PM
Default RE: internal vs external
The two main problems or issues that you can have with internal wastegates is the boost creep and also not holding the boost as well (or power as well) as an external wastegate. It just will have alot more steady boost
Old 01-17-2008 | 12:57 AM
c577's Avatar
ah, ic, so thanks, wats a good size/brand for an e316g
Old 01-17-2008 | 01:31 AM
dorian7's Avatar
I did the 34mm internal wastegate upgrade for my Evo III (ported) that I just installed at I run 15-16psi and have NO noticable boost creep, it holds it steady too. I was actually quite impressed with how steady it is. If you plan on running over 20 all the time then it is no issue for the stock 32mm. It is a crap load cheaper than an external too.
dorian7
01-03-2008 03:14 PM
ash_kimura
02-07-2007 12:54 AM
DSMTalonAWD51
06-07-2006 06:29 PM
96tsi
04-11-2006 01:28 AM
tapnguts
11-29-2005 01:59 AM
