internal vs external
Old Jan 16, 2008 | 12:51 PM
c577's Avatar
Default internal vs external
what are the pros. cons. of internal and external wastegates?
[align=left] [/align]
Old Jan 16, 2008 | 04:07 PM
Default RE: internal vs external
The two main problems or issues that you can have with internal wastegates is the boost creep and also not holding the boost as well (or power as well) as an external wastegate. It just will have alot more steady boost
Old Jan 16, 2008 | 11:57 PM
c577's Avatar
ah, ic, so thanks, wats a good size/brand for an e316g
Old Jan 17, 2008 | 12:31 AM
dorian7's Avatar
I did the 34mm internal wastegate upgrade for my Evo III (ported) that I just installed at I run 15-16psi and have NO noticable boost creep, it holds it steady too. I was actually quite impressed with how steady it is. If you plan on running over 20 all the time then it is no issue for the stock 32mm. It is a crap load cheaper than an external too.
dorian7
Jan 3, 2008 02:14 PM
ash_kimura
Feb 6, 2007 11:54 PM
DSMTalonAWD51
Jun 7, 2006 05:29 PM
96tsi
Apr 11, 2006 12:28 AM
tapnguts
Nov 29, 2005 12:59 AM
