jacking point
Old Jun 6, 2006 | 03:11 AM
5Tizzle's Avatar
Default jacking point
Tried jacking up my car today, and i dont know if im using the correct jacking point. I jacked up on the little rail that sticks down below the door, and it bent it a little bit.
where is the correct jacking point[&:]
Old Jun 6, 2006 | 12:36 PM
reacted's Avatar
Default RE: jacking point
you should be able to see a bar, right near the rear of the front tires. its a little further in there so take a look before you start jacking you can damage the car pretty bad..
Old Jun 9, 2006 | 06:39 PM
slvr_eclipse's Avatar
on any unibody carl always jack on the pinch welds of the rocker panel as close to the tire as possible...that is the strongest point there is atleast 3 layers of UHSS (ultra high strength steel) welded together at these points...its should never damage them by just jackng the car up. Definetly stay away from the floor. Caving that in effects a lot of things even airbag timing if in a collision. if its dented or creased it with fold into itself a lot easier.
Old Jun 9, 2006 | 09:25 PM
Sanguinius's Avatar
Exactly. Always use the pinch weld. And alot of cars have 2 small halfcircles put the jack between them and you'll be fine.
Old Feb 9, 2016 | 08:07 PM
nskmda's Avatar
Default Front jack point on 2012 Lancer?
Where is it located? Is there such thing for my Lancer?
I wanted to change oil but the manual only gives me points on the sides.
How can I raise the front of the car to get to the oil plug / filter?
Old Nov 22, 2021 | 09:20 AM
Homer1959's Avatar
car ramps are the best for oil change
Old Dec 3, 2021 | 05:15 PM
nskmda's Avatar
Thanks. That's kind of obvious.
But I am not sure everybody can afford building a car ramp for a mere oil change. Or everybody has a friend who owns a car shop...
So, my question is still unanswered...
I'm not sure if 2012 Lancer SE even has that front jacking point, tho.
Main reason 4 asking was to use the front jacking point to raise the car to put stands under sides (pinch welds, of course).
Old Dec 3, 2021 | 09:27 PM
Homer1959's Avatar
I was answering NSKMDA just above my post and you dont have to build car ramps or spend a fortune ... That may help https://www.evolutionm.net/forums/04...-safe-way.html
n0c7
Jun 5, 2013 10:38 PM
9LIVEZ
Dec 21, 2008 02:35 PM
clips69
Jun 4, 2007 02:31 PM
Sebba
Jul 29, 2006 01:21 PM
NESpeed
Feb 7, 2006 03:23 AM
